johnkreeft
- Oct 26, 2025
2020 Indian Motorcycle
Trim: Scout Bobber Sixty ABS Standard
Excellent condition - Runs and drives like new!
No trades, please.
After-market seat, exhaust, and fork tubes.
Clean title.
engine displacement: 1133 CC
3,822 miles
SPECS...
Engine & Drivetrain
Bore x Stroke: 3.898 in x 2.898 in (99 mm x 73.6 mm)
Compression Ratio: 10.7:1
Displacement: 69 cu in (1,133 cc)
Drive/Driven Clutch" Wet, Multi-Plate
Electronic Fuel Injection System: Closed Loop Fuel Injection / 60 mm Bore
Engine Type: Liquid Cooled V-Twin (60 degrees)
Exhaust: Split Dual Exhaust w/ Cross-over
Horsepower: 100 HP
Peak Torque: 72 ft-lbs (97.7 Nm)
Peak Torque RPM: 6,000 rpm
Transmission/Primary Drive: Gear Drive Wet Clutch
Dimensions
Fuel Capacity: 3.3 gal (12.5 L)
Ground Clearance: 5.1 in (130 mm)
Lean Angle: 29°
Overall Height: 41.5 in (1,053 mm)
Overall Length: 87.5 in (2223 mm)
Overall Width: 36.5 in (926 mm)
Rake/Trail: 29.0° / 4.7 in (120 mm)
Seat Height: 25.6 in (649 mm)
Weight (Empty Tank / Full of Fuel): 552 lbs / 572 lbs (250 kg / 259 kg)
Wheelbase: 62 in (157.6 cm)
Brakes
Front Brakes: Single / 298 mm Rotor / 2 Piston Caliper
Rear Brakes: Single / 298 mm Rotor / 1 Piston Caliper
Tires / Wheels
Front Tires: Pirelli MT60RS 130/90B16 67H
Front Wheel: Cast 16 in x 3.5 in
Rear Tires: Pirelli® MT60RS 150/80B16 77H
Rear Wheel: Cast 16 in x 3.5 in
Suspension
Front Fork Tube Diameter: 41 mm
Front Suspension
Telescopic Fork
Front Travel: 4.7 in (120 mm)
Rear Suspension
Dual Shocks
Rear Travel: 2.0 in (51 mm)
Features
Color / Graphics: Thunder Black, Thunder Black Smoke, Bronze Smoke, White Smoke, Deepwater Metallic
Gauges: Digital tachometer, odometer, trip meter, engine temp and low fuel lamp
Lights: Headlight, tail/brake light, turn signals, license plate light, speedometer and indicator lights.
No trades, please.
Clean title.
3,822 miles
SPECS...
Engine & Drivetrain
Horsepower: 100 HP
Dimensions
Lean Angle: 29°
Brakes
Tires / Wheels
Suspension
Front Suspension
Telescopic Fork
Rear Suspension
Dual Shocks
Features
- Condition
- Used
- Indian
- Scout Bobber Sixty ABS Standard
- $6,900
- Reading
- Massachusetts - MA
