CampFireJack
Pro Member
- Harley Davidson
- Dyna Wide Glide Custom
- $5900
- Sterling
- Minnesota - MN
The motorcycles of the Dyna line are considered to be the best handling and most versatile performance leaders amongst Harley's big twins. Their relatively light weight makes them a natural choice as the basis for a hot rod bike which has led generations of customizers to build Dyna’s of every imaginable type and style. This beauty has a gorgeous custom flame paint job with flames that start yellow and fade to red with a blue pin striping that sounds just plain nasty with its Vance & Hines Long Shots exhaust. It has been upgraded with the following H-D additions: Chrome 5 spoke wheels, detachable windshield, tach (w/ visor), lower spoiler, luggage rack as well as 2” extended forward controls. Almost every imaginable option you can think of has been added to this bike with a list of upgrades longer than your arm. Some of the highlights include tear drop mirrors, a speedo visor, tail light visor, Hot Bolt topper kit as well as steel braided cables (& lines). Additionally, you will also find the following genuine H-D chrome parts: grips, pegs, switches, switch housings, levers, tank panel, gas cap cover, lower legs, fork boot covers, axle covers (front & rear), voltage regulator cover, points cover, starter cover, trans door cover, engine to trans cover, top shock covers, master cylinder covers, sprocket cover, lower belt guard, derby cover, petcock valve cover, horn cover, clutch cable cover (& clamps) and a chrome headlight bezel. This particular bike has been completely customized using genuine Harley-Davidson parts almost exclusively with add on parts totaling in excess of $12,000. There are a few very minor flaws which include some flaking chrome on the inner primary, a small scratch in the paint and a small ding in the heat shields all of which are shown ion the photos. With the exception of these minor flaws you would be hard pressed to believe this beauty has 31,703 miles. It was recently serviced by our local H-D mechanic and is ready to roll. We have basically priced this as a stock bike so if you like what you see you better not wait until it’s too late to pick up the phone!
John D. Moore
STERLING MOTORS INC
www.hotrodschoppers.com
John D. Moore
STERLING MOTORS INC
