- Apr 12, 2019
I'm Selling 2017 Polaris Slingshot SL for $12,500 with 1,072 miles. Great condition inside and outside mechanically in order and inspected. Negotiable feel free to contact me for any questions.
Standard Features - Performance
2.4 Liter DOHC Engine
5-Speed Manual Transmission
173 HP with 166 ft.-lbs. of Torque
Standard Features - Driver Aids
Electronic Power-Assisted Steering
Electronic Stability & Traction Control
ABS Disc Brakes
Standard Features - Driver Comfort
Adjustable, Waterproof Seats with 3 Point Seatbelts
Tilt Steering
Standard Features - Lighting
Projector Beam Headlights & LED Taillights
Standard Features - Storage
Lockable Storage Bins and Glove Box
Dimensions/Capacities
Max Wet Weight: 1749 lbs.
Overall Length (in/mm): 149.6 in/3800 mm
Overall Width (in/mm): 77.9 in/1980 mm
Overall Height (in/mm): 51.9 in/1318 mm
Track Width (in/mm): 69.1 in/1755 mm
Wheelbase (in/mm): 105.0 in/2667 mm
Ground Clearance (in/mm): 5.0 in/127 mm
Powertrain
Engine: GM Ecotec LE9 2.4L DOHC
Displacement (cid/cc): 2384 cc
Bore and Stroke: 88mm x 98mm
Compression Ratio: 10.4:1
Valve Train: DOHC, VVT
Fuel: 91 octane or higher
Performance
Rev Limit (RPM): 7200 RPM
Peak Power (HP): 173 HP @ 6200 RPM
Peak Torque (ft-lbs): 166 ft-lbs @ 4700 RPM
Fluid Capacity
Fuel (Gallons/Liters): 9.77 Gallons / 37.1 Liters
Brakes
Brake Rotors (Front): Vented cast iron, 298mm diameter
Brake Rotors (Rear): Vented cast iron, 298mm diameter
Wheels and Tires
Front Tire Type: Kenda SS-799
Front Tire Size: 205/50R17
Front Wheel Type: Cast Aluminum
Front Wheel Size: 17x7 J
Rear Tire Type: Kenda SS-799
Rear Tire Size: 265/35R18
Rear Wheel Type: Cast Aluminum
Rear Wheel Size: 18x9.5 J
Transmission
Clutch Type: Dry, Single Plate, Hydraulically Actuated
Transmission Type: 5 Speed Synchromesh with Reverse
1st Gear Ratio: 3.753:1
2nd Gear Ratio: 2.258:1
3rd Gear Ratio: 1.512:1
4th Gear Ratio: 1.000:1
5th Gear Ratio: .729:1
Reverse Gear Ratio: 3.672:1
Gear Shift Pattern: H
Bevel Drive Ratio: 2.312:1
Final Drive Type: Carbon Fiber Reinforced Belt, 36mm x 147T
Final Drive Ratio: 1.590:1
Steering
Actuation: Rack-and-pinion
Assist: Polaris EPAS, Speed Sensitive
Steering Turns, lock-to-lock: 3.2
Electrical
Battery: 30AH, 12V, 400 CCA
Lighting
Headlight: Projector H9 65w
Auxiliary Light: Projector H3 55w
Tail/Brake Light: LED
Turn Signals: LED
License Plate Light: LED
Speedometer & Indicator Lights: LED
Driver Aids
ABS (Anti-Lock Brakes): Standard
ESC (Electronic Stability Control): Standard
Traction Control: Standard
ABS Disc Brakes
Tilt Steering
Powertrain
Performance
Fluid Capacity
Brakes
Wheels and Tires
Transmission
Steering
Electrical
Lighting
Turn Signals: LED
Driver Aids
- Condition
- Used
- Polaris
- Slingshot SL
- $12,500
- Hollywood
- Florida - FL
